Mesh in Archicad not showing in 3D
I've drawing the mesh in 2D and its shown up before but im not sure what i pressed cause now when im in 3D it seems to be transparent but I am still able to highlight it! any ideas how to fix this???
thanks!
As I recall you get this phenomenon when the Mesh element's 3D geometry is degenerated so ARCHICAD cannot display it in 3D. You still see its nodes when you select it though.
You could either delete it and redo it, or you could find where exactly the Mesh is degenerated. It is usually a single place in the Mesh. I usually do this:
0. Create a duplicate of the Mesh and work with that.
1. Split the Mesh into two Meshes using the Split command. Usually you will see that now one of the two resulting Meshes now displays correctly in 3D. You will then know that the problem is in the other part of the Mesh.
2. Split the problematic resulting Mesh again into two Meshes. Continue this until you can pinpoint exactly where in the Mesh geometry your error is.
So I found this forum which seems to be having the same issue...
https://archicad-talk.graphisoft.com/viewtopic.php?t=39047
but im not sure how to uncheck 'Filter elements in 3D'... where can I find this??
