Mesh to Morph problem
Zendrix
Hi!
Im having an issue that was kind of posted here before, but it was accepted as solved, so i did not know if i should expose it there or create a new topic.
I have a wall mesh that im trying to convert to morph after an intersection operation with a terrain.
After i choose "convert to morph" the terrain goes back to its original shape. I have seen tutorials doing this and this outcome not happening. What am i missing?
BTW, i am trying to design a kerb that follows the terrain slope.
Thanks
AC28 . LeNovo Y520 Intel Core i7-7700HQ @ 2.80GHz 8GB RAM. Windows 10 Home
4 REPLIES 4
BYAArchitects
Wow! having the same issue converting a mesh to morph. Thanks for posting this. I await with baited breath!
I'm doing cut and fill calculations on my mesh and want to lock the SEO operations into the mesh.
BYAArchitects
I just worked out how to make the morph from a mesh (ArchiCAD 27);
1. Select the morph tool
2. Magic wand all faces of the mesh so that you convert each face to a morph.
3. Turn off the mesh layer, select all of the faces to the 3D volume you need.
4. Right Click the selection and do either;
(a) "check solidity" (then if it gives the option) tell it to "make solid", or
(b) "Boolean Operations">"Union"
There you have it!
Zendrix
Hi!
Glad you found a way!
But im guessing that is a workaround to a problem, and i was looking for what is the cause of the actual problem, because having seen the operation be made in a simplier way makes me wanna know what is happening wrong. I am looking for speed and efficiency while using archicad.
Thanks
cuba
You could also create a more detailled kerb with a complexprofiel as a beam or with the railing tool.
Workflow with walls:
Apple M1 Max 32 GB Ventura
AC27
