Mirror a beam and lose it's correct profile. ?
I have this molding made as a beam. When I mirror the beam it loses it's smooth profile. Does anyone know why it might do that?
http://screencast.com/t/wDLfAwnB
4 REPLIES 4
vistasp
Hi Steve. I tried it with one of the standard profiles and it mirrored fine. On an off chance, I tried it with different magic wand settings and even with different beam angles (30°, 45°, 60°) but that made no difference.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
vistasp
One weird thing, though. At 45° (and not at 30 or 60), if I deleted the original beam, the copied one was truncated perpendicular to its angle and not vertically. Bug?
EDIT: Changed the profile to one of the simpler ones and it worked as expected. Changed it back to the original complicated one and this time it worked as expected.
= v i s t a s p =
bT Square Peg
DGSketcher
Legend
Works ok here. Possibly a geometry issue in the source profile.
May be worth redrawing / tracing the profile to see if that fixes it.
I didn't need the profile to be a beam for any special reason other than to use it on the slope. What I ended up doing it using one of the moldings, convert to morph and rotate so I can use it on the slope. Down side is that I know the client is going to want to change that profile several times before he decides on what he wants. I wanted to be able to update that complex profile everywhere at once. Also, it was to be in a schedule I have to tweak now for morphs.
What I would really like is if the molding I am using had the option for slope.
The good news is that andro55 posted the gdl script I can add to the molding object for rotation.
