Kaj_AL
Model a brick corner
Hi!
I'm digitalizing old drawings to make an IFC model of a building. It has a brick facade, meeting a plaster facade.
How would you model this kind of meeting?
It's a plastered concrete wall with a brick layer on the outside.
Thank you!
/Kaj
Archicad 24-27 SWE
Dell Precision 5560, Windows 11 Pro
11th Gen Intel(R) Core(TM) i9-11950H @ 2.60GHz 2.61 GHz
1 Solution
aarkell
Could you have two wall composites, one with brick and plaster (red), one with just plaster (green)? Have those join as normal, and then have an L-shaped column via a complex profile that is only brick (blue)? That's one way I can think after a quick glance, but there may be others.
Andrew Arkell
AC 18-27 USA 5030
HP Z6 G4 Workstation | Intel(R) Xeon(R) Gold 6226R CPU @ 2.90GHz | Windows 11
Go to post
2 Replies 2
aarkell
Andrew Arkell
AC 18-27 USA 5030
Kaj_AL
Yeah, that worked great, thank you!
/Kaj
Archicad 24-27 SWE
