Modify wall length question
Is there an easy way to modify the length of two opposite walls in a rectangle of walls that have been created using the "chain of walls" tool? I have been able to stretch of shrink a single straight wall by selecting it and clicking the end point. When I do that, I get the menu option shown in the first picture.
When I click the end point of a chain of walls, I no longer get the option to add or subtract from it. (See the second picture.)
Is there a way to shrink two sides of the rectangle of walls, leaving the other two sides as is?
Brett wrote:
Click on the face of the walls while all selected and then you will get the pet pallet you need.
Here is an image to help explain.
Brett Brown
Imac, Big Sur AC 20 NZ, AC 25 Solo UKI,
It worked! I had to suspend grouping to get the menu. Thank you much.
