jojojojojojojojojojo
Moving multiple Mesh Points at once
Hi!
I have already a mesh that is based on a point cloud that i imported with the Surveyor Data Command. Therefore, it has a lot of points. During the design process of a project, I would like to alter the terrain a bit and thought it would be easiest just by moving multiple points at once and just playing around with what looks best. However, exactly this seems impossible. I can of course move the individual points, but selecting more doesnt work, not with the Shift Key and also not with the Marquee Tool. Does someone now a trick? Or a workaround?
Thank you! Jo
2 Replies 2
If the points are on a contour line, you can adjust the height of one point and then tick the 'Apply to all' button.
Individual points you will have to adjust one by one.
Or maybe this will help?
https://community.graphisoft.com/t5/Modeling/Mesh-Consolidation/m-p/712345/highlight/true#M180195
