Multi-angled custom roof edge
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
ā2017-06-19
01:51 PM
ā2023-05-23
02:17 PM
Rubia Torres
From what I can see, the custom edge function allows for the edge to be customised at one angle only.
Is a multi-angled custom edge achievable with the roof tool, or is this a job for complex profiles?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2017-06-19 06:00 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2017-06-20 08:33 AM
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2017-06-20 11:02 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2017-06-20 11:04 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2017-06-20 11:36 AM
Kieran wrote:You modify the element or elements shape or rotation that you are using for the SEO and your roof edges will adjust accordingly.
Thanks Erwin. Would cutting the roof edge with solid element operations then allow me to change each angled surface individually?
The advantage of the SEO is you can use it on a real roof rather than making a complex profile beam or wall and trying to use that as your roof.
You can use a complex profile to do the cutting in the SEO or you could use a series of single roof planes to get the angles you want and use them together in the SEO.
In your example you would only need one the get the end or bottom angle, the other angled surface can be the actual edge of your roof.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2017-06-20 12:43 PM
Though, let's say that in materialisation stage you decide to work with some sort of panels, it would be possible to model those panels individually with single plane roofs, for example. Breaking up your one shape in to several individual planes, which then are easy enough to manipulate by themselves.
We compare it to being in a helicopter, slowly descending and the closer you get to the ground, the more detail you will see. First drafts are rough, once you have your desired look, start working on the details.
www.leloup.nl
Windows 10 Pro
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2017-06-21 08:25 AM
Barry wrote:So in the case of SOE, I'm still not sure how I can manipulate the newly created surface. The black top edge seems to be the only one I can change (being part of the original edge). Even with surface painter (which I don't want to use), by clicking on the new edge surface I want to change, the whole roof changes to a uniform colour instead of one surface.
My understanding is that surface painter only works for 3D representation anyway. I would like changes to be represented in all views.
Barry wrote:Also with using another element as the 'cutting operator', do I just give it it's own layer and then hide that layer?
Thanks for your patience, I'm sure it will sink in soon.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2017-06-21 08:32 AM
www.leloup.nl
Windows 10 Pro
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2017-06-21 08:44 AM
