2017-06-19 01:51 PM - last edited on 2023-05-23 02:17 PM by Rubia Torres
2017-06-19 06:00 PM
2017-06-20 08:33 AM
2017-06-20 11:02 AM
2017-06-20 11:04 AM
2017-06-20 11:36 AM
Kieran wrote:You modify the element or elements shape or rotation that you are using for the SEO and your roof edges will adjust accordingly.
Thanks Erwin. Would cutting the roof edge with solid element operations then allow me to change each angled surface individually?
2017-06-20 12:43 PM
2017-06-21 08:25 AM
Barry wrote:So in the case of SOE, I'm still not sure how I can manipulate the newly created surface. The black top edge seems to be the only one I can change (being part of the original edge). Even with surface painter (which I don't want to use), by clicking on the new edge surface I want to change, the whole roof changes to a uniform colour instead of one surface.
The advantage of the SEO is you can use it on a real roof rather than making a complex profile beam or wall and trying to use that as your roof.
Barry wrote:Also with using another element as the 'cutting operator', do I just give it it's own layer and then hide that layer?
You can use a complex profile to do the cutting in the SEO or you could use a series of single roof planes to get the angles you want and use them together in the SEO.
2017-06-21 08:32 AM
2017-06-21 08:44 AM
