B_Migito
Multi-modules railings
Hey everyone,
I'm trying to model multi-modules railings like this (see images below) but I can't find a way to get the curved part in-between each module
My questions are :
  • Is it possible ?
  • If yes, how would I need to configure my railings to get the desired output ?
  • If no, how would you go about modeling something like that ?
First image is where I got. The others are references
Garde-corps d'escalier en métal noir avec accessoires de montage en forme  de U pour balcon, couloir et appartement _ Amazon.fr_ Bricolage.jpg
I couldn't pick the archicad version and OS version in the menu but I'm on archicad 26 and 28 running MacOS 15.3.2
Operating system used: Mac Apple Silicon 15 Sequoia
5 Replies 5
CosminF
I tried to model something based on your pictures and I couldn't succeed to have independent elements. In theory, there might be a possibility of achieving this with curtain wall tool (only on a horizontal plane) but I didn't explore that very much.
A possible workaround would be to model just one element and just use an array to distribute it (if the railing is on a horizontal plane). If its a stair railing, again, you can manually distribute it on each step.
Cosmin Furdui - architect @ Wincon
AC 27, running on Windows 11 Intel(R) Core(TM) i7-14700K CPU64, 3.40GHz, 32GB RAM, Nvidia GeForce RTX5060 32GB
I can't say I have attempted anything quite like this before.
It could be possible to create a custom balustrade (or maybe a custom post) for that last image (the black railings), turn off the handrails, rails and posts.
Then make sure it is distributed with one baluster or post per tread.
But that could all be a bit messy to do.
For that one I would just model something and distribute it on each tread.
For the first two, you could do them as separate railings for each short segment.
That way you can turn down the ends of each segment because it would be the start and end ao an entire railing.
B_Migito
Hi Barry and Cosmin
  • Yes, it was possible to create a custom post for the lblack railing Capture d’écran 2026-07-13 à 08.37.21.pngCapture d’écran 2026-07-13 à 08.37.46.png
  • For the other type of railing, I got close enough with panels and strategically placed posts but it's not what I was looking for. I've been trying to get a custom GDL object to act as a custom panel but without success Capture d’écran 2026-07-13 à 08.38.16.png
  • Looking at the Panel 3D_m.gsm object (seems to be how graphisoft does railing panels) feels too time-consuming so I'll leave it as is for now.
Lingwisyer
Guru
Just a query, but is this actually legal where you are? Stairs in Australia require a continuous handrail on at lease one side.
B_Migito
To be legal, the gap between the rail should not be more that 5cm but yes it is.
Mind you, that will depend on what is the destination of the project : if it's a construction that needs to receive public (and thus be PMR friendly : for persons with reduced mobility) then it's to be avoided.
If it's for a home owner (like the black railing on the interior stairs) , they can do pretty much what they want
You mostly see that type of railing at docks (marina) or industrial constructions
