4 weeks ago
Hey everyone,
I'm trying to model multi-modules railings like this (see images below) but I can't find a way to get the curved part in-between each module
My questions are :
First image is where I got. The others are references
I couldn't pick the archicad version and OS version in the menu but I'm on archicad 26 and 28 running MacOS 15.3.2
Operating system used: Mac Apple Silicon 15 Sequoia
4 weeks ago
I tried to model something based on your pictures and I couldn't succeed to have independent elements. In theory, there might be a possibility of achieving this with curtain wall tool (only on a horizontal plane) but I didn't explore that very much.
A possible workaround would be to model just one element and just use an array to distribute it (if the railing is on a horizontal plane). If its a stair railing, again, you can manually distribute it on each step.
4 weeks ago
I can't say I have attempted anything quite like this before.
It could be possible to create a custom balustrade (or maybe a custom post) for that last image (the black railings), turn off the handrails, rails and posts.
Then make sure it is distributed with one baluster or post per tread.
But that could all be a bit messy to do.
For that one I would just model something and distribute it on each tread.
For the first two, you could do them as separate railings for each short segment.
That way you can turn down the ends of each segment because it would be the start and end ao an entire railing.
3 weeks ago - last edited 3 weeks ago
Hi Barry and Cosmin
3 weeks ago
Just a query, but is this actually legal where you are? Stairs in Australia require a continuous handrail on at lease one side.
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 7800X3D | 32GB | RTX5070TI |
To be legal, the gap between the rail should not be more that 5cm but yes it is.
Mind you, that will depend on what is the destination of the project : if it's a construction that needs to receive public (and thus be PMR friendly : for persons with reduced mobility) then it's to be avoided.
If it's for a home owner (like the black railing on the interior stairs) , they can do pretty much what they want
You mostly see that type of railing at docks (marina) or industrial constructions
