‎2014-12-30
12:48 PM
‎2023-05-23
02:28 PM
Rubia Torres
‎2015-02-20 05:40 PM
‎2015-02-21 12:47 AM
‎2015-02-21 01:17 PM
Steve wrote:I am not seeing this bug, I can select and move the ends of the Roof pivot lines in the 3D Window. When I select the pivot line the Pet Palette appears.
Here is another time when I can't select even the node.
‎2015-02-22 02:45 PM
Steve wrote:If you have the Coordinates Palette showing, you will see that the Angle is locked, keeping the movement of the Door parallel to the direction of the Wall. If you unlock the Angle (option-A on Mac), you will be able to move the cursor to the Line to find its center point while dragging the Door. The Door will still move along the angle of the Wall.
I want to center the door in the middle of a line. The snap point should pop up when I move my cursor onto the line. It does not. I have to let go of the door highlight the line so the snap pops up, and then hurry back to grab the door and move it before the snap disappears on me.
I don't like having to put the cursor on the line first, then move the door.
It should work either way.
‎2015-02-22 11:21 PM
‎2015-02-22 11:43 PM
‎2015-02-23 05:50 PM
‎2015-02-23 07:22 PM
‎2015-02-23 08:15 PM
‎2015-02-23 08:40 PM
