2012-07-30
11:21 PM
2023-05-26
02:26 PM
Rubia Torres
2012-09-05 01:00 AM
2012-09-05 01:21 AM
2012-09-05 08:30 AM
2012-09-05 10:05 PM
PB wrote:Yes--now using Lion on a MBP 15" retina.
Dave, your signature shows a Retina MBP......are you now using AC16 on this, & have your problems disappeared?
2012-09-07 12:47 AM
Dave wrote:I will look a little deeper to see if there is a change between the two but upon testing it just now I don't see a difference in behavior. A possibility that a migrated work environment from a previous version is in the mix?
This only malfunctions for me in AC 16. Still works fine in 15.
Dave wrote:I will see about reviewing the help documentation and see if we can improve it.
I've been using AC long enough that I can usually figure out any issues that come up, but I've been referring to the HELP pages quite a bit the last few days and have come to realize that they leave a lot to be desired. The explanation for those controls could definitely be explained better.
Dave wrote:If there is indeed a bug we will investigate it. You are welcome to contact us directly at "support at graphisoft dot com"
Because logic wasn't working for me, I have tried every combination of the tracker and coordinate input settings with no joy.
2012-09-07 07:13 PM
NCornia wrote:Using Tracker without the Coordinates Palette gives me exactly the same (incorrect) results. This is what happens: Choose the Line Tool (Polyline, etc.) - Click to start - keyboard entry A - enter value - keyboard R to set length and the A value in Tracker reverts to 0 or if using surveyor's unit, reverts to N 90 E. I've experimented with every combination of settings in WE>Tracker & Coord. Input with no change in results. I would like to remedy this soon, as it is a huge pain in the posterior to draw property boundaries.
Dave et al,
My recommendation for users going forward is to use the Tracker but it's not a mandate.![]()
2012-10-30 03:10 PM
2012-11-28 02:28 AM
2013-01-16 06:41 AM
Dave wrote:So, Graphisoft has been able to reproduce this problem. We've also discovered why some folks suffer and others do not experience the problem. In WE > User Preference Schemes > Tracker and Coordinate Input, selecting the "Prefer polar coordinates in Tracker..." option turns on the bad behavior--and it doesn't seems to be reversible. Unselecting it and drawing results in AC misbehavior.NCornia wrote:Using Tracker without the Coordinates Palette gives me exactly the same (incorrect) results. This is what happens: Choose the Line Tool (Polyline, etc.) - Click to start - keyboard entry A - enter value - keyboard R to set length and the A value in Tracker reverts to 0 or if using surveyor's unit, reverts to N 90 E. I've experimented with every combination of settings in WE>Tracker & Coord. Input with no change in results. I would like to remedy this soon, as it is a huge pain in the posterior to draw property boundaries.
Dave et al,
2013-04-10 11:17 PM
Dave wrote:One further note on this issue: You must enter the length of the line first, then the angle. If you enter the angle first, then hit R to enter the length, the angle reverts to a bad number.
The problem has been passed along to Budapest. In the meantime, there does seem to be a workaround, though I don't believe it worked in AC 15 (where I first noticed this problem). If you enter N 45 15 E for the angle, the result is correct--that is, do not enter N45 15E as you are supposed to be able to do, but include a space between the compass points and the numbers.
If that doesn't work for you, please post here. I'm not sure when this became a viable workaround, because I tried this and countless other gymnastics in the past with no luck, but it has been working for me without fail for about a week now.
