2004-06-15 04:57 PM - last edited on 2023-05-26 12:43 PM by Rubia Torres
2005-01-28 01:06 PM
2005-01-28 01:35 PM
Donald wrote:It depends on how you understand the offset and whether you expect to use it in the same way as you did in let's say AutoCAD or anything else, OR you realize that not all software works the same way and try to first see the way the particular one does.
I repeat, in my opinion the offset command is, in practice, not simple and, i find, unreliable. And why can't you offset a single line?
2005-01-28 02:10 PM
Paul wrote:
You can , sort of....
Not as elegant or ergonomic in terms of key presses, but you can just drag a copy or multiple copies with perpendicular lock on, (perp with reference to original element)
I do this all the time.
Does not address single arcs or ellipses annoyingly as radii do not change to suit offset.
Keith wrote:
1. You've got to be in 'line' or 'arc' mode to offset
2. If you try and offset a group comprising lines and arcs, and you're not in 'arc' mode when you do it, your offset arcs end up as a mass of tiny straight lines.
3. You can't offset polylines.
4. You've got to enter the offset dimension every time, preceeded by that 'R' thing.
2005-01-28 02:15 PM
2005-01-28 06:14 PM
2005-01-31 05:48 PM
2005-02-09 08:52 PM
2005-02-09 09:05 PM
2005-02-09 11:23 PM
2005-02-09 11:33 PM
