‎2007-07-28 12:38 PM
‎2007-11-22 05:29 AM
‎2007-11-22 10:12 AM
s2art wrote:Hmmm, let me check that out. I tried it just before posting to make sure I wasn't speaking erroneously and it did NOT work. But, I will try the metric.
Rex
Using value- works for me. Don't know what the setting might be that prevents it, unless its a metric vs imperial thing?
‎2007-11-22 05:07 PM
Rex wrote:I am not using Imperial units. So in the Metric world, VALUE + works as well as VALUE -. If you have X-Y in Imperial, it means XfeetYinches, therefore ...Djordje wrote:Djordje, you can't use VALUE-. It has to be -VALUE+. Unless I'm seriously missing some setting to allow this.steveacad wrote:If you want to start anything at a distance from an existing point, place the cursor there, type xVALUE+, press enter and the cursor will jump the VALUE to the right. You can also use yVALUE+, or VALUE-. Can be also used for Z coordinate in 3D, and also for R.
Is there an offset tool, or a jump tool from a snap point in the drawing?
‎2007-11-27 01:10 AM
Djordje wrote:Dude, you are preaching to the choir! One day in 7th grade math class, back in the '70s, our teacher changed the lesson plans and gave us a long speech about how the US was converting to metric, and that by the time we graduated, "miles, inches, pounds, etc." would be a memory... Nope.
Would it not be high time that the US stopped preserving the British monarchy legacy?😉 To paraphrase DNC, even they accepted the metric system, even if it is French!😉
‎2007-11-27 02:04 AM
Rex wrote:x 3 -
If you wanted it to be 3m to the left of the point, then -3+ would be the data to type ...
... 3m down is y, then -3+.y 3 -
‎2007-11-27 02:27 AM
‎2007-11-27 05:26 AM
Link wrote:That's the one I was thinking of, but having never used Imperial units...
But in imperial, since the - is used to separate feet and fractional inches you'll have to type -- for the last method if that's what your working units are set to.
Link.
