Offsetting Walls
Hi Im new to the forum but very interested!
Can anyone tell me how can you offset a wall from any given point. For example if I draw a rectangle room of 10 x 5 metres how can I start a new wall say 3 metres on the 10 metre length.
Is there an offset tool, or a jump tool from a snap point in the drawing?
Please help!
16 Replies 16
Rex
Using value- works for me. Don't know what the setting might be that prevents it, unless its a metric vs imperial thing?
s2art wrote:
Rex
Hmmm, let me check that out. I tried it just before posting to make sure I wasn't speaking erroneously and it did NOT work. But, I will try the metric.
Nope. Didn't work. What it does for me is absolute from 0,0 values, not relative to the point.
Interesting.
Rex Maximilian, Honolulu, USA - www.rexmaximilian.com
ArchiCAD 28/29 (user since 3.4, 1991)
16" MacBook Pro; M4 Max (2024), 48GB RAM, 1 TB SSD, 32-Core GPU
Apple Vision Pro w/ BIMx
Creator of the Maximilian ArchiCAD Template System
Djordje
Rex wrote:
Djordje wrote:
If you want to start anything at a distance from an existing point, place the cursor there, type xVALUE+, press enter and the cursor will jump the VALUE to the right. You can also use yVALUE+, or VALUE-. Can be also used for Z coordinate in 3D, and also for R.
Djordje, you can't use VALUE-. It has to be -VALUE+. Unless I'm seriously missing some setting to allow this.
I am not using Imperial units. So in the Metric world, VALUE + works as well as VALUE -. If you have X-Y in Imperial, it means XfeetYinches, therefore ...
Would it not be high time that the US stopped preserving the British monarchy legacy? 😉 To paraphrase DNC, even they accepted the metric system, even if it is French! 😉
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Dude, you are preaching to the choir! One day in 7th grade math class, back in the '70s, our teacher changed the lesson plans and gave us a long speech about how the US was converting to metric, and that by the time we graduated, "miles, inches, pounds, etc." would be a memory... Nope.
I think Reagan killed it when he took office. At least that was the reason I heard.
I'm guessing almost every US designer, architect and engineer would welcome such a change. Using a base 12 measuring system in a base 10 world really sucks.
__archiben
uhh. really?
Rex wrote:
If you wanted it to be 3m to the left of the point, then -3+ would be the data to type ...
x 3 -
... 3m down is y, then -3+.
y 3 -
surely?
~/ben
b e n _ f r o s t
Link
Assuming you have Relative coordinates checked in either the Tracker or the Coordinates Box:
-3 = 3 back from where the edit origin is (which will be where you selected your wall unless you manually changed it mid-operation with Alt+Shift);
-3+ = 3 back from where the cursor is;
3- = 3 back from where the cursor is (as above);
But in imperial, since the - is used to separate feet and fractional inches you'll have to type -- for the last method if that's what your working units are set to.
Link.
Link.
That's the one I was thinking of, but having never used Imperial units...
... although I'm still 5'7"
