Parapet wall feature in Archicad
Tamchount
Hi I was used to Archicad 22 an older version that wasn't updated, now that I'm using Archicad 28 I can't seem to find the parapet wall feature that I could normally access by going to wall types, but I can't find it in this version. I'm so lost andIi have no idea what to do I can't seem to find  anything on the internet or online.
Please help.
CosminF
Are you referring to railing element? If so, there is a new button for it.
AC 27, running on Windows 10 Intel(R) Core(TM) i7-9700K CPU64, 3.60GHz, 16GB RAM, Nvidia GeForce GTX1650
Eduardo Rolon
AFAIK there has never been a dedicated parapet wall feature since by definition it is a wall.
Need more information or screenshot of what you are referring to.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
vistasp
Perhaps it was set up as a favourite in the template you used earlier? As Eduardo says, more info is required.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
Setup info provided by author
