2010-05-03
03:08 PM
2023-05-23
02:57 PM
Rubia Torres
2017-04-30 09:30 AM
raoultittel wrote:Actually the opposite is true. The safest and most powerful thing to do is to set up in your building file 'story module export' views. With an 'export view', you can decide which layers get exported to the module, which not only makes files lighter but also allows you to use the same layer for different content at the site, building (and also unit plan, building component, furniture, and whatever you are using module creation for) levels. Then you create a 'Story module' Publisher Set, which publishes .mods to a 'Story Modules' folder, from which you place your modules on the site plan. It sounds complicated when reading it and it may well sound that doing the opposite is 'simpler', but learning the procedure is a 5 min investment at most, which will pay for itself pretty much straightaway. The only thing I am not sure about yet is how well this works with BIM Server and long-distance work.
Suggestions that you make a module from the elements in a PLN file and Hotlink them into your master file a risky work-around at best.
2017-04-30 01:53 PM
2017-07-19 02:28 PM
2017-07-19 03:11 PM
