SJPHouse2
Purge Unused Surfaces
Hello - is there a way to purge unused surfaces more than one at a time as a group - or is it only possible to purge them one by one via Options > Element Attributes > Surfaces? Thanks!
Mac OS Big Sur / AC23
1 Solution
@SJPHouse2 wrote:
I don't have that as an option - 'Attribute Manager' does not appear
It looks like you might be using a custom Work Environment?
Attribute manager should be there in the standard WE.
Or you can add it you your own custom WE if you want.
Also look in your tool bars - you may have it as a button somewhere.
Go to post
5 Replies 5
hevi
Ace
Yes, through Options > Element Attributes > Attribute Manager.
It allows for batch purge of unused attributes. Used attributes are indicated by the checkmark and for it to be considered unused it cannot be used in placed elements, favorites and tool defaults, or other attributes.
Lingwisyer
Guru
Though I am pretty sure the "used" attributes includes anything in your favourites...
Win11 | i9 10850K | 64GB | RX6600 Win11 | i9 11900K | 32GB | GTX2080TI
SJPHouse2
I don't have that as an option - 'Attribute Manager' does not appear- are you running AC23 or an earlier or later version?
SJPHouse2
Hi Barry - looking for the button did it, thank you!
