Question on "Show Selection/Marquee"
Space_Agency
Anyone know of a method or command to go one step back if for example you select 6 objects and then hit F4 or "Show Selection" and then select 3 of those 6 objects and hit F4 or "Show Selection" to go back to the 6 object selection instead of going back to the entire model/"show all"? I.e. is there a technique or menu to go back one selection/isolation step?
Operating system used: Mac Apple Silicon 14.7
Archicad V26 /V27 USA
MacBook Pro M1 Max
ram 64GB
Mac OS Sonoma 14.2.1
Switch back to the floor plan and the original 6 should still be selected.
Then show selection in 3D again.
James B
Alternatively, you could store the selection in the Selections palette.
https://help.graphisoft.com/AC/28/INT/#t=_AC28_Help%2F030_Interaction%2F030_Interaction-32.htm&rhsea...
James Badcock
Graphisoft Senior Product Manager
Great solution for storing particular selections (I always forget about it).
But in 3D you will still have to 'show all' then activate that selection and then 'Show selection' again to bring back your original selection.
Or still switch back to the floor plan, activate selection and show selection in 3D.
Setup info provided by author
