Rectangular Wall Method.
The pop-up window that includes the Rectangular Wall Method does not appear when I click on the Wall Method farthest left inside the Info box (Linear Wall Method?).
Following the training guide, I encountered a step which requests that I select the Rectangular Wall Geometry Method. The Geometry Wall Methods that appear by default do not include the Rectangular Wall Method, but only the (linear one?) which is farthest left of the other Wall Methods.
The video showed that when clicked-on it turns into the Rectangular Wall Method (by means of a pop-up window). Well, it does not happen for me. If I select the marquee tool, then The Rectangular Wall Method appears, but this is not how it is shown in the video. What detail am I missing?
Activate the wall tool and type g; if you watch the info box, each time you hit g, the Geometry Method change and you will toggle through the various Geometry Methods and see where they are.
woodster
PS. Make sure no objects are selected when you do this or you will be seeing information about the selected item in the Info Box rather than information about the wall tool itself.
Djordje
Hold the mouse button pressed, don't just click.
Or, use the method described by Woody.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
