2008-04-05 07:45 PM
2008-08-01 03:31 PM
Steve wrote:I respectfully disagree.
If ArchiCAD was all that it could be, there would be no need for Constructor.
2008-08-01 04:12 PM
Krippahl wrote:I'm with Krippahl on this one. Some tools are different enough to have similar functions but different goals. It's like saying "If Word was all it could be, there'd be no need for PowerPoint and Excel". They have have overlapping abilities (like tables and formatting text) and still require a full program for the specific goals.Steve wrote:I respectfully disagree.
ArchiCad is a design tool, and a BIM one on that.
VICO is a construction management tool, which happens to share the same building module as Archicad..
2008-08-01 04:26 PM
2008-08-02 01:00 AM
Krippahl wrote:Steve wrote:I respectfully disagree.
I really don´t want to have to worry about how many teams of carpenters will be allocated to a specific floor on a specific schedule, or to compare biddings from subcontractors to build the structure, while I am designing the architectural solution.
Don´t mistake Constructor for VICO, because it is only a third of the suite.
2008-08-02 02:00 AM
2008-08-02 02:05 AM
2008-08-02 02:07 AM
Dennis wrote:Yes. I did have to download a newer version of net frameworks.
slightly off topic, but my Constructor demo hangs during installation. it says it's doing some .net framework or something like that...
did this happen to u at all steve?
2008-08-02 10:20 AM
Steve wrote:My bad, sorry. Still, Constructor is not just ArchiCad with more modelling capabilities, it has all the linkage capabilities to Estimator, Control, 5D presenter, Cost and Change manager, Databases, etc.
I was not comparing ArchiCAD to VICO Software, only to Constructor.
Steve wrote:Well, I´m really not sure about that (Site survey yes, but that is a minor point). Have you ever tried to model MEP with Constructor from your engineers drawings? Because this is what you are asking for.
I am talking only about the ArchiCAD add-on's like the MEP Modeler, SiteSurvey, etc...which are part of creating the BIM.
2008-08-02 02:29 PM
Steve wrote:The MEP modeller was the DuctWork (HVAC for ArchiCAD) add-on, developed at Cymap with Graphisoft. It was much more than objects, providing full 3D duct routing, automatic connection of ductwork and outlets (with branches, tees, reducers etc), and wall penetrations. It also managed ductwork systems. It originally worked in ArchiCAD (before Constructor existed).
Where did Vico get the MEP Modeler and the other add-on's for ArchiCAD that come with Constructor? I think it is entirely possible that they came from Graphisoft in the first place.
2008-08-04 11:09 AM
