ā2004-11-09
11:40 PM
ā2023-05-23
05:25 PM
Rubia Torres
ā2004-11-10 12:50 AM
ā2004-11-10 02:16 AM
ā2004-11-11 10:35 AM
ā2004-11-22 06:05 PM
ā2004-11-22 06:56 PM
ā2004-12-21 04:48 AM
ā2006-09-11 10:58 PM
ā2006-09-12 12:29 AM
ā2006-09-12 09:37 AM
But as noted here, I didn't see anything obvious in the Work Environment to modify...You need to edit the Edit menu, under Command Layout Schemes>Menus. Unfortunately there's no easy way (AFAIK) to move everything in a sub-menu into the main menu in one go, so you need to remove and re-add each item individually.
Any comments?
I also would like to know how to do it with AC10.Should be the same. I wouldn't fret though, because it's still not easy to tell what you are editing AFAIS.
Even after modifying registry, my current context menus aren't listed in the Working Environment to edit them.
Strange... since doing it in AC9 was so easy.
