Right to left text in AC9 and ACX
I have just started to work with Archicad 9 on old existing projects, and ACX on new projects.
The new text editor does not display hebrew letters as I type them in or as I edit them. I assume this is the same with arabic text. Is there a solution ??? Is there a way to go back to the "old" text input method.
Djordje, have you picked up arabic in the UAE ?
Naftali
ArchiCAD 9, Archicad 10 Build 933, WinXP Home
2 Replies 2
Djordje
Regretfully, I picked up less Arabic that I would have liked or wanted ... but I picked up a lot of Dinglish 😉
Frankly, I did not try Arabic on 10 at all. Will check and get back to you ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Naftali wrote:
After playing around with it a little more, I accidently hit the return key, and all of a sudden, I saw the text. One line text is still invisible during input, whether it's English or Hebrew. Nobody else has this problem ???
Naftali
AC9 ACX Build 9xx, WinXP Home SP2
