Tom Krowka
Roof Cornice
We do a lot of high end residential that requires ornate trim details at the gable ends, rake returns, etc. What's the best way to make those quickly and accurately?
I've experimented; please correct any assumptions following:
Profiler only works in XY axis.
Moldings can be made to rotate in 3d, but they show up incorrectly in plan view while they show up correctly in elevation and 3D view. (I did this by adding a "roty r" command in the 3d script, and a new paramter "R" with the type set to angle). In plan view they are moved away from their positions in elevation; it must have something to do with the hypotenuse of the angle or something. And I sure don't know how to program it.
I purchased the Fast Cornice HHD found on objectsonline, but it's too simple, and I can't get trim where I need.
I was looking at other eave creators on objectonline, "eaves" and "eave designer". Is anyone else using them for this kind of detail?
Thanks in advance for the input.
Tom Krowka Architect
Windows 11, AC Version 26
Thomas@wkarchwk.com
www.walshkrowka.com
8 Replies 8
Link
I think ArchiForma does all that - and more. Ask Fabrizio or check out www.cigraph.com
Link.
i use archiforma for rakes. its the only thing that will tilt them to your pitch. i use the crowns/trims in the archicad 8.0 library for fascia and returns. its a good collection of trims and works very well. Then i use the wall tool for all rectanglar, horizontal facia area trims. i use the slab tool for all soffitts. the wall tool works well for water tables, slab tool for corners boards. set wall tool to polygon mode and if you have your route laid out its very quick and clean.
donald mac donald
Donald,
How do you go about re-using the cornices you have created? Save as Modules or Build a typical drawing file that is modified for each job?
Thanks
Djordje
You will build a library of corniches in time; if you are using ArchiForma, all the objects are graphically editable after creating.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Thanks... GS may as well buy Cigraph and bundle all their apps with AC.. All Cigraph apps seem to be what AC hopes to be when it grows up..
Erika Epstein
Djordje wrote:
You will build a library of corniches .
I thought " corniche" was rolls royce?
Showing your penchant for classic cars?
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Djordje
My favourite classic is a Beetle, but, since VW bought RR ... oh, wait, it was BMW, VW bought Bentley 😉
Djordje
HP Omen
Tom Krowka
I guess the consensus is to buy ARchiforma and be done with it. How long did it take for you to be productive with it. I'm still on the ArchiCad & Architerra learning curve.
Thanks for the input.
Thomas@wkarchwk.com
www.walshkrowka.com
