2 hours ago
Hello everyone,
i cant find any article about situation im in. The thing is my roof needs to have different layers inside and out. For example, inside on the last layer there should come 2 gypsum plaster boards, but outside on the last layer it should be an aluminium plate. I was searching for Profile Manager solution but it doesnt work on roofs. Do you have any particular solution for this kinda problem where i can modify the layers of the roof or in worst case scenarion i have to turn roof into morph in order to do that kinda thing? Im just looking for the best solution. Thanks!
2 hours ago
Have you looked into composites? or am I misunderstanding what do you actually need? Do you need the aluminium plate to be profiled? if so, usually you can model it afterwards with roof accessories.
