2008-11-11
07:56 PM
2023-05-23
03:07 PM
Rubia Torres
2008-11-11 08:13 PM
2008-11-14 10:33 AM
s2art wrote:Not an alternative ... there is no need to use SEO for a hole in the roof.
You cannot delete the Operator. It must remain in the model (on a layer turned off if you like) for the operation to work. Whenever the operator is moved, the SEO operation moves accordingly. Always live.
An alternative in your situation, though, would just be to make a hole in your roof (select roof, and with roof tool active draw the shape of the hole).
2008-11-14 02:49 PM
Djordje wrote:One use for SEO through 3D polygon elements is so that you can assign the materials of the edge of the hole (the SEO option where the materials of the operator, not the target, are used). It would be helpful to be able to assign different materials to the edges of holes (via pet palette, similar to changing the edge angle of roof elements) so that this would not be necessary.
The same way, you do the holes in any other polygon (mesh, fill, slab ...)
2008-11-14 03:15 PM
