Room Finish Schedule for MEtadate - Need to add Finishes
I have gone brain dead today.
I have a finish schedule with elements I have added
Ceiling - Acoustical
And Ceiling Finishes I failed to add AT1, At2 and AT3
CANNOT remember how I added other finsihes like I did for Floor finish, Base Finish Etc.
Eric Milberger, Architect | Master Planner
4 REPLIES 4
Found it - Had to go to OPTIONS-PROPERTY MANAGER
As a newby it woudl be nice if this was coontrolled all from one menu - at least where to go.
You can customize all the menus in the work environment or even just make your own special menu with all the stuff you want to click on so that you always have that one spot to go and or map key combinations to activate said tools or items
Right now too busy to learn and create a project.  No time for anything else.
I used to be to busy to save time too, then I saved time and now I'm as busy as I want.
