Rotating objects in the vertical plane
I've downloaded a few GDL objects and I can't figure out how to rotate the objects on the vertical plan. I can easily rotate on the horizontal plane, as with all objects. I tried changing the plane to vertical, but that did not help. Any suggestions would be beneficial. Thanks!
I'm not sure if this is the right way but try morphing the object. Worked for me.
Correct me if there's a better way forum members.
Try this free Object (Rotator.gsm) for rotating other objects:
http://archicad-talk.graphisoft.com/object_depository.php?browse=Depository/Archicad%20Modules
