‎2006-06-03
08:23 PM
‎2023-05-26
03:08 PM
Rubia Torres
‎2006-06-04 01:43 AM
‎2006-06-04 03:14 AM
‎2006-06-04 05:11 AM
habiatuq wrote:I just checked the AC10 markers and they don't have any way to free rotate them. If the "Marker direction" parameter doesn't do what you want you will need to try something else.
Hi Matthew,
The window I am using comes for the "ArchiCAD Library 10" which came with AC. Do you know if such dynamic handels, whch you hhave refered to, are available for such Library part?
I have looked in all the availble settings, but couldn't find anything that would rotate the Marker ID.
You have mentioned that one can edit library parts to meet specific needs. Is this something that biggernes could do?Editing library parts can be quite simple and it can be mind numbingly complex. This one falls somewhere in between. If you feel so inclined (and are fairly mathematical/logical) you should give it a shot. It may be easier to start from scratch. Some of the standard parts are quite complicated in order to be all things to all people. You just want something to do a couple of things exactly the way you want.
‎2006-06-04 05:13 AM
‎2006-06-04 01:07 PM
Djordje wrote:This seems to have been much simplified in 10. I just wrote a basic door tag and keeping the text horizontal is trivial. Come to think of it, it may have always been this way. The keys I have written as far as I can remember had to align with the wall or the door leaf - this gets more complicated.
Only the text should be rotated - or always horizontal, IMHO?
DEFINE STYLE "text_style" "Arial", 2.5, 5, 0 STYLE "text_style" Circle2 0, 0, 0.004*GLOB_SCALE rot2 -SYMB_ROTANGLE Text2 0, 0, AC_WIDO_ID
‎2006-06-05 06:12 AM
‎2006-06-05 05:33 PM
‎2006-06-05 06:05 PM
