2017-09-26 04:26 PM - last edited on 2023-05-23 02:15 PM by Rubia Torres
2017-09-26 10:14 PM
Lilith wrote:I don't quite follow your description of the problem. It looks like everything in the lower picture has been cut. ?
I've trimmed few objects using SEO, and as seen in the image few of them got trimmed ...
2017-09-27 08:38 AM
2017-09-27 12:32 PM
Steve wrote:the "cut" is properly shown in 3D view, but in floor plan the whole object is shown (dashed hatch)Lilith wrote:I don't quite follow your description of the problem. It looks like everything in the lower picture has been cut. ?
2017-09-27 01:13 PM
Erwin wrote:Thanks for confirming. I wasnt sure if I was doing something wrong, or if there's a way to make slabs behave as expected.
I think it is about floorplan.
SEO on mesh will not show up in floorplan.
Roof will show SEO.
You could convert the mesh to a morph (I would keep a copy of the mesh and SEO on a seperate layer with an unique intersection group number for future editing). It should show fine in floorplan and 3d and gives you the benefit of hiding or showing edges.
2017-09-27 01:18 PM
2017-09-27 01:54 PM
Erwin wrote:thank you a lot for such fast replies.
Roofs use a true projection. Slabs are symbolic.
Roofs do not participate in priority based connections (with building materials), though, where slabs do. There are a few more perks where finish layers meeting windows/doors will automatically extend with slabs.
2017-09-27 02:19 PM
2017-09-27 03:59 PM
Erwin wrote:Roofs do participate in priority based connections, just not automatically like Slabs do.
2017-09-27 05:20 PM
Erwin wrote:thats a fascinating fact. Never occured to me that it could be an issue.
Netherlands is for a large part very flat country where basements are rare. I do not draw terrain that way, sadly.
