Section Marked Distant Area
Paul King
Mentor
I must be going crazy here, but can not for the life of me seem to access the section marker 'distant area' function any more.
Placing a section marker with limited horizontal extent, the extents marker is adjustable, but there is no distant area line I can adjust.
The Marked Distant Area parameter heading within the marker setting dialog is not active (does not expand out to reveal settings when clicked)
What am I missing?
Is this a bug?
PAUL KING | https://www.prime.net.nz
ArchiCAD 8-29 | Twinmotion 2025
Windoze 11 PC | Intel Core Ultra 9 285K | Nvidia Gforce RTX 5090 | 64 GB | 2x4K monitor extended desktop
Which ARCHICAD version is this?
Can you show a screenshot of what is happening exactly?
James B
If the Section Horizontal Range is set to "Zero Depth", then there are no Marked Distant Area settings.
James Badcock
