Section cutting plane normal to a road path
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2021-07-03 10:10 AM
2021-07-03
10:10 AM
Thanks in advance
Solved! Go to Solution.
13 REPLIES 13
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-07-15 08:00 PM
2021-07-15
08:00 PM
at that time i did not check as it should the same setting as the other quote, but I'll check right now ....
It is set to measured value
By the way I also tried to set the working plane parallel to the custom cutting plane before I inserted the quotes, but the result is the same.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-07-15 09:13 PM
2021-07-15
09:13 PM
I did some tests, and it seems that you have used the roof with vertical edge, right?
Then if you select the roof top and bottomnodes in the 3d doc, it will give you the vertical dimension.
On the other hand, if you select the roof top and bottomedges , it will give you the correct one.
Can you confirm this?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-07-15 11:29 PM
2021-07-15
11:29 PM
I do confirm that selecting the edges instead of the nodes the quote return effectively the right thickness, I did change the roof edge setting a couple of time to see if it change something: it seems it doesn't. Anyway I post my initial roof settings.
You definitely found what I could have never imagined it would have an effect on the quoting result. Well done. Bravo!
Let's hope this post will help someone else!!
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-07-16 11:12 AM
2021-07-16
11:12 AM
You are welcome.
Well... IMO it looks like a bug.
Perhaps contacting your local support about this issue would be a good idea.
- « Previous
- 1
- 2
- Next »
- « Previous
- 1
- 2
- Next »
