Section
Please, anybody knows why my sections take for ever to regenerate, even when the view it is already saved?
Thanks
Regeneration has more to do with the amount of polygons to generate than to it being a View or not.
You should check your model: if it has any layers turned on in the View that contain high polygon elements, such as Trees or complicated GDL objects. Then you can turn the layers of those elements off to speed up regeneration.
I will try that.
Thanks.
