Shadows in 3D
Red
Is there a settings within Archicad to have full sun light without any shadows when using opengl for 3D??
Thanks,
Red
i7 8700k
ROG Strix Z390-E MoBo
64gb RAM
EVGA GeForce GTX 2080
_______________________
http://www.facebook.com/flatcreekdesignstn
http://www.sraarchitects.biz
6 REPLIES 6
Djordje
Ace
Switch the sun shadows off.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Ted Taylor
Did you mean shading? On my Mac, OpenGL doesn't cast shadows but does shade the sides away from the sun. I was having difficulty with the shaded sides being too dark until I figured out it could be controlled by adjusting the light parameters in the Sun Dialog box found under Image:3D Projection Settings...:More Sun button. Setting all of the parameters to 100% gives me no shading and all sides are equally lighted.
Ted Taylor
Atlanta, GA , USA
iMac (Retina 5K, 27", Late 2015)
3.3 GHz Intel Core i5 32GB
AMD Radeon R9 M395 2GB
OS10.14.2,
Latest Archicad 22
Erika Epstein
Ted,
That's an interesting workaround.
One of my wishes is that in the navigator to have a button that allows the sun to always be positioned behind the camera so when checking a model everthing is always lit.
Uncheck to render.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Erika wrote:
Ted,
Uncheck to render.
Good idea! It shouldn't be too hard to do as this feature already exists in the QTVR object rendering.
Uncheck to render.
Great wish, Erika! I don't think this is on the wishlist yet? Please post over there if not. If I could suggest a minor variant: a button as well as an angle and azimuth setting so that the sun would follow the camera around at that position - which I usually prefer to be slightly to the left or right of dead-on.
One of the forum moderators
AC 27 USA and earlier   •   macOS Ventura 13.6.9, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Karl wrote:
Uncheck to render.
Karl,
This is what the QTVR setting does already. I would hope they would simply adapt the same function. Set the relative sun in the 3D settings dialog and check the "follow me around" option.
