‎2006-09-22
04:56 PM
‎2023-05-25
05:58 PM
Rubia Torres
‎2006-09-22 10:04 PM
‎2006-09-23 02:08 AM
‎2006-09-23 09:50 AM
‎2006-09-23 11:35 PM
‎2006-09-24 04:11 PM
‎2006-09-25 10:31 AM
‎2006-09-28 02:38 PM
Krippahl wrote:Surely this will result in a line between the beam and the slab which would not look right in section?
The cleanest workaround (for me) is:
- Take the composite slab only to the inner face of the wall.
- Make a beam with the same height than your slab, and position it against said slab, inside wall.
- with the new composite beams, you can even have many layers of floor 'entering' the slab.
- Group your beam with the outer wall, so it won't get misplaced.
- As the beam subtracts from the wall volume, you get correct quantities.
‎2006-09-28 03:16 PM
‎2006-09-28 06:39 PM
