Slab problem
Hello
I've seen a video when an instructor drew a slab over 2D 1 story level for flooring and when I did the same it was drawn over the roof not the floor....I can't figure out what's wrong I just followed as shown in the video....I can attach a link of the video if allowed.....I just started using ArchiCAD so any help will be much appreciated
Dontknow
Make sure you've got the 'Home-Story' and the 'Offset to Home-Story' set right.
Architectural construction designer, draftsman, modeller
ArchiCAD 25.
Solved!!! Thank you
