Slabs and floor plan cut plane
Nik
How do you stop slab elements that are above the floor plan cut plane from appearing on plan views? For example we have window reveals and other elements that are very high up (way above the cut plane), but are still appearing on the plan view despite setting the cut plane and range. Any thoughts?
Cheers, Nik
30 REPLIES 30
Slabs don't react to Floor Plan Cutting Planes.
They don't have the ability to be symbolic, projected or overhead as other elements do.
I do wish there was consistency for all tools (goes the same for show on storeys).
I would add them into a "Slabs - 3D" layer, so you can turn them of in your floor plan layer combination, but leave them on for your section, elevation and 3D layer combinations (when ever you want to see them).
Thanks Barry, that's what I suspected.
It's very frustrating that you can't simply create a cut plane and see exactly what you would see if the model were cut at this point. We spend so much time playing around with layers, display order, cut/projected/overhead settings, etc just to get the plan to look the way it should. I guess it's the same reason that solid element operations don't show in plan, which also drives us crazy!
Nik
I only use slabs for floors and ceilings.
i use objects or other tools so that i can control them better with the cut plane.
doing so results in less time messing with things for sure. all about reducing keytrokes!
That’s right Nik, using ā€˜projected/projected with overhead/cut only’ is so 2010. Please make it possible to see exactly what is cut by the cutting plane, like Revit. What you see is what you get.
The way you look at walls, slabs, columns, etc. needs not to be defined by the object but by the view.
Vanessa1
agree that this is a super-basic industry-standard capability that is not offered. Slabs used for ceiling/ shadowline or joinery elements having to be assigned layers to control visibility when the visibility graphics is otherwise so advanced is extremely primitive.
No its not. It is extremely flexible.
There is no "super-basic industry-standard capability" in any CAD/BIM software unless you mean one (i.e. Revit) and if you are honest they only changed the name.
Why is it so hard for new users to get the idea that AC is not Revit?
A per view setting only means that if you make a mistake in 100 views then you need to edit 100 views individually. But noooooo, you may say we can define groups of views and edit them at the same time in Revit but then you are using the equivalent of AC's Layer Sets and Layers just with a different name.
Though I do agree about the SEOs rep in plan…
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
@Barry ,
How about in some drawings I want to see the dashed outline of slabs above AND the normal outline of slabs on the floor, but sometimes I just want to see the slabs on the floor, not the outlines of the ones above...
Tricky, isn't it?
Not to mention that sometimes I just want to see a proper ceiling representation based on the model...
And if you say I should use 3D doc, then I cry. šŸ˜‰
ArchiCAD since 4.5
Windows, Mac
Have you considered using a zero degree roof? I think I saw that they will be adding reference line selection to roofs too in the near future which makes this more viable. Though they should just make things consistent already, which is also on the road map...
Tricky, isn't it?šŸ˜‰
If you want to see slabs dashed in one view and solid in another view, then you would have to use Graphic Overrides to change the line type for the particular slabs, using criteria such as ID to filter just the slabs you want.
If you don't want to see the outline of the slabs above, then use layers to turn them off.
I have never use a 3D Document to produce a ceiling plan yet (not that I do many of them).
I am happy to just use layers.
But this way you don't have control of the view of elements based on the FPCP.
However, elements you don't want to see can be in layers you can turn off.
Display of doors and windows can be controlled with MVO.
