Solid Element Operator & 3D Loading Issue
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2025-04-03 12:34 AM
Hello Everyone,
We are working in ArchiCAD 28 and we are having problems with our solid element operator working properly and when we do have the operations performed it will take upwards of 5+ minutes to load / update 3D views and Sections. We are not doing any more operations than we normally. The few projects that we have working in 28 are proto type projects so we have modeled them in previous versions of ArchiCAD before without these problems.
When we perform a solid element operation it doesn't always work. So we undo and redo the operations and once we get the problem operation to work it makes another operation to not work. I don't believe I am performing the operation in a different manner than I have in pervious versions so I am not sure what is doing on. I am hoping someone else is experiencing this and maybe has a fix to get the operations to work. We can live with a little longer loading times (but 5 minutes is a little ridiculous) but we need the operations to work so things are presented correctly.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2025-04-03 02:39 AM
So if you find and cancel all of the SEOs, the file performs OK.
Don't save the file if you cancel the SEOs.
What type of elements are you trying to SEO?
Can you show some images?
Are you SEOing elements that have SEO already to other elements with SEO?
Can you show an image of the SEO list of connections?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2025-04-07 05:25 PM
I was able to work through the solid operation glitch. I had to perform them in smaller groups than normal.
I am not sure how I am able to take a picture of the slow loading time. It just says that is 'Updating 3D'. Not sure what to do about that.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2025-04-08 02:50 AM
I meant images of what you are SEOing.
And how many SEO interactions you have on each element.
Try to use them sparingly and keep them as simple as possible.
