2005-09-16 04:17 AM
2005-09-16 05:42 AM
2005-09-16 06:12 AM
2005-09-16 09:51 AM
Rashid wrote:Is your roof a composite? In that case the thickness is a fixed value.
This must have been covered elsewhere but I can't find it.. How to trim rafter to less than 8" so the fascia board can cover it..
2005-09-16 01:22 PM
2005-09-16 05:16 PM
2005-09-16 05:31 PM
Rick wrote:To get around the random changes in roofs , such as trusses, joists, soffits, etc, we took the position of making the roof only be the sheathing, and combine it with a custom fascia/gutter object (which used to be done with beams, but people wanted gutters & sloping capability).
What I do, and yes it's a pain, but the easiest work around I know how to do.. is generate your roof with the needed composite thickness, say 2x10 rafters. Then split the roof at the outside stud line. Change the eave part you split off to the needed composite/thickness.. say 2x6 roof. Then in section align the top of the roof surface. You can then transfer the new attribute of height to the other eaves with the drug (syringe) tool.
Please go to this link and vote...if you haven't already.
http://archicad-talk.graphisoft.com/viewtopic.php?t=7727
2005-09-16 08:43 PM
2005-09-16 08:54 PM
Rashid wrote:Maybe this makes a bit more sense (just as an example. I know there is no structure here.)
I voted a while back, hopefully not in vain. Not quite clear on Tom's method. I ended up with SEO slabs as the Profiler soffit did not want to operate.
2005-09-16 09:10 PM
