Wlad222
Surface (texture) override problem
Hi everyone,
I’m having an issue with Material Override. It works on most surfaces, but on the edges/corners of walls I still get a very thin line showing the original material.
In the attached image you can see that the walls are mostly overridden correctly, but along some edges there is a visible dark/original-material outline. It looks like the override is not fully applying to edge faces or small bevel/side faces.
Has anyone experienced this before?
1 Solution
Rico Suleyman
It's because that part is the edge of the wall, which in your case doesn't have its surface override active.
You need to activate this option to use the surface of the adjoining wall:
Go to post
3 Replies 3
Wlad222
Additional screenshot: It has to do with wall merging?
Rico Suleyman
Wlad222
Thank you Rico!!
