Thursday
Hi guys Im currently struggling with making tapered slab like this for 2 sides of my building ( I still need 100-150mm thick on the edges ) . Please help, thanks all
Thursday
You can't taper a slab, at best you can set its edge angles to be other than 90 degrees but that will edit all edges:
To model that you can either make a custom profile and extrude it or model it with the morph tool.
Thursday - last edited Thursday
You can set them individually by going through the Custom Edge Settings.
Do note that in both cases, the rotation is from the top edge regardless of your reference point, and is not represented in the Floor Plan
Ling.
Thursday
I stand corrected. Thank you Ling!
Thursday
this is the one im looking for but i dont know how to do it
It's hollow? I would use a Complex Profile in conjunction with probably the Beam Tool. You can replicate it for the roof too.
