Timber Framers using Archicad?
I am involved in residential design, specifically with timber framed houses. To clarify for the international members here, this means using timber larger than 6x6's (8x8, 8x10, 6x8 etc) and not 2x4's which seems to be the nomenclature outside of North America. I have googled and searched for examples of timber framers using Archicad but have found very little. I know that log home builders like Archicad (possibly because of ArchiLog). I presently use a combination of Autocad, SketchUp and Cadwork. Cadwork is an timber specific program (generates CNC code etc) but I don't really like it for the architectural development and presentation side.
My questions are-
1) Do any of you know of good examples of Archicad being used for timber design?
2) Is native Archicad the tool for timber design? I am aware of Framewright but this seems over kill for what I'm looking for. Objective looks quite useful but is it being supplanted by the morph tool?
3) I need an acis (sat) file at the end of my design process in order to bring the design into Cadwork. Is there an easy process from Archicad?
Kris
25 REPLIES 25
There are some, but for some reason I don't see them on these forums wearing that hat.
Encina in the UK created a timber framing add-on for AC some years back that had a light and a full version. Now that Cadimage bought them, it seems they only produce the Pro version - and it is not clear how long they will continue to do so. See:
http://www.cadimage.com/Products/Tools/Framewright
Here are the search results for posts that mention this add-on:
http://www.archicadwiki.com/results.html?q=framewright
If you do not need to schedule and dimension individual timbers or send out CNC code - e.g., visual and erect timbers (elevations/sections) are good enough, then you can shape things with complex profiles and.or morphs.
One of the forum moderators
AC 27 USA and earlier   •   macOS Ventura 13.6.9, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Karl,
Thanks for your comments. Hopefully the timber framers are too busy to visit the forum.
Do you have anything to offer re: Objective vs morphs. I would at least like to get some kind of object list with timber sizing and length. I understand that Objective has some attributes which morphs don't. Am I correct here?
Do you have any comments on achieving a sat export?
Kris
Dave Seabury
Kris
Not a timber framer, But I do a lot of houses with timber framing in them.
I have worked out the following process for coordination w/ the timber framers. I group timbers and put them on their own layer ie Timbers-Entry,
Timbers Kitchen, Timbers Living Room etc. When I have every thing modeled I export out a 3d dwg or dxf and they import that in to there software. the layers are exported as well so they can isolate specific areas
to work on. They will quite often use my layouts for there shop drawings as well. I prefer objective for modeling the timbers as you can rotate the objects easily as will as cut them and change lengths/sizes etc.
AC 19-24 Windows 10 64 bit, Dell Prercision 7820, Xeon Silver 2414R ( 12 Cores), 64 GB Ram, Quadro RTX 4000 8GB
Dave,
Thanks for your answer. Do you know if the timber objects come into dwg as a 3d solid. Don't know if dxf does this. I realize that Achicad isn't a solid modeler (and there in lies the conversion problem tp programs which generally generate CNC code) but if I have a reliable and not too onerous method of conversion to sat format, that will be good.
Kris
Dave Seabury
Kris
I called one of the timber framers I work with and they import my file into ashlar vellums 3d program and convert the objects to solids, from ashlar they can export files for cnc processing. So I guess it can be done just not directly out of AC.
David,
Thanks for investigating. I do a similar thing now but use a program called ViaCad which has an acis kernel. This method works quite nicely. I can see a workflow coming together. By the way, I like your entry. I am a carpenter by trade and am definitely a wood guy.
Kris
NCornia
Graphisoft Alumni
Graphisoft Alumni
Kris,
At the GRAPHISOFT North American User Conference in October 2013 there was a great presentation about a timber frame construction designed by one of our users. He used the model to go to CNC process. I will contact the user and see if he can add more to the conversation.
Best regards,
Nicholas Cornia
Technical Support Team - GRAPHISOFT North America
ARCHICAD on Twitter
Tutorials
GRAPHISOFT Help Center
MrC
Hi KrisM. We use archicad exclusively for our timber frame designs. Very flexible. Haven't found anything we weren't able to model ….. SEO's and Morphs used a lot,especially for knee braces and arched beams.
ILIFFE ARCHITECTURAL
BRITISH COLUMBIA
macbook pro 2.7 GHz Intel Core i7 8 GB 1600 MHz DDR3 NVIDIA GeForce GT 650M 1024 MB
AC 21 USA (latest build)
MrC,
Thanks for the image. Nice. Are you just using the native Morph tool? Are you familiar with Objective? What about outputting a material list?
Kris
