Turning Off Trace Reference
this may be a silly question, but how does one turn off the trace reference after opening a source view with layout as reference? It is a very nice feature when arranging layouts, but I find it distracting when working on the actual drawing. Thanks.
11 Replies 11
Shift+F2 by default (on mine at least)
vfrontiers
right clk with nothing selected... bottom of palette = TRACE... you can toggle OFF here.
Better yet, in the same context menu, it lets you put up the TRACE palette.
Duane
Visual Frontiers
AC3.14 - AC29
:|: Enscape4.16:|:TwinMotion
vfrontiers
I used to love TRACE... now it is so stinking slow, I can get anything done...
Kind of like trying to use the schedule like EXCEL and type in a bunch of values... It is PAINFULLY SLOW..
Duane
Visual Frontiers
AC3.14 - AC29
Thank you both. I did each of them, and both work fine. I do not like using icons any more than I have to, so the Shift/F2 will be my choice. Thanks again.
I'm preferring icons at the moment: broken left arm makes some key combinations a little awkward , but the Shift+F2 shortcut was easier to describe.
vfrontiers
I actually prefer having the TRACE PALETTE up on my screen all the time. There is so much more you can do with the palette, like....
1. Adjust the color of the trace reference (and of the CURRENT items)
2. Flip the display order where the Trace is on top of the Current.
3. And more....
Duane
Visual Frontiers
AC3.14 - AC29
Sorry to hear you are injured, s2art. So, please tell me, vfrontier, what are the practical uses of the trace feature. I came to this position straight after getting my AutoCAD Certificate ( I sold heavy equipment parts for 15 years prior) and have had no training on ArchiCAD. I am self taught. I have over the past two years gotten pretty proficient, but anything that I can learn will make this program even more enjoyable. I have to use AutoCAD at home periodically, and I hate it now.....
Dennis Lee
Trace Reference is very crucial to my work. When I start a project, I have several stories below the first story set up for References. I have the assessor's map, aerial photo from google, as built site plan, floor plan, elevations etc., and use them at various times of design - as well as during layouting, doing plan / elevation comparisons, etc., etc.
I have the trace pallette toggle set to keyboard shortcut T so whenever I need to modify the colors or the transparency and such I just hit T and it shows up.
Very, very useful, UNIQUE and fantastic feature of AC, I must say.
ArchiCAD 25 & 24 USA
Windows 10 x64
Since ArchiCAD 9
Here is an excellent article on Trace Reference by Eric Bobrow:
http://www.aecbytes.com/tipsandtricks/2008/issue28-archicad.html
Lots of examples in it for possible uses.
