2004-05-01
08:58 PM
2023-05-25
06:05 PM
Rubia Torres
2004-05-02 12:05 AM
2004-05-02 01:09 AM
2004-05-02 04:23 PM
2004-05-02 08:10 PM
Tom wrote:Tom, how would you build it?
Thanks. I can see where it should be a wish list item for sure. If I draw zero height walls in the middle of a tall wall, won't it screw something up?
Will I see a line in the interior wall when viewed in section or an interior camera?
2004-05-02 08:39 PM
Djordje wrote:If this is to remain the case then some other features must be added to smooth the workflow. First, windows and doors must be able to insert properly across a wall joint, whether horizontal or vertical. Next, we need some way to link connected walls, again both horizontally and vertically, and across stories so one little adjustment doesn't become an hour's worth of realignments.
Double and triple height walls should NOT be one wall.
2004-05-03 11:30 AM
Geoff wrote:May I also suggest a wall that goes floorlevel to floor level (ie: forget the floor inbetween?Djordje wrote:If this is to remain the case then some other features must be added to smooth the workflow. First, windows and doors must be able to insert properly across a wall joint, whether horizontal or vertical. Next, we need some way to link connected walls, again both horizontally and vertically, and across stories so one little adjustment doesn't become an hour's worth of realignments.
2004-05-03 11:09 PM
2004-05-04 06:50 AM
2004-05-04 03:25 PM
