johanes
Undo roof trim in Archicad 19
Does anyone know where is the command "Undo roof trim" in Archicad 19? I knew that is found in the properties of the object are cut. In Archicad can not find 19 this command ...
2 Solutions
Dontknow
Select the wall, richt click and select Connect' and 'Clear All Connections'.
Architectural construction designer, draftsman, modeller
ArchiCAD 25.
Go to post
James B
You may be referring to the Crop command.
Design > Roof Extras > Undo All Crops
James Badcock
Go to post
2 Replies 2
Dontknow
ArchiCAD 25.
James B
James Badcock
