The value of the IFC Property is now displayed in the Label.
Some Notes:
* In the
Symbol Label panel of the Label Setting Dialog, you can uncheck the
Use Symbol Arrow checkbox, in which case the Label will draw a Leader Line and arrow.
* The 1. Block of the Generic Label is usually the ID field. But you can make the Additional Tags the 1. block instead of the ID, you don't have to always display the ID. Or you can select the
** Empty Row option for the 1. Row with the same result.
* At the bottom of the
Content and Display Order page of the
Custom Settings panel of the Label Settings Dialog, there is a
Display Data by field. Here you can set to display only the
Parameter Value if that is the desired output (this is the setting I used for the attached image).
* As you probably know it is possible to set default settings for Labels by going to the Label Settings Dialog with no Label element selected. However, in this case the list in the Additional Tags page will not be populated with IFC Properties. This is why you have to select a Label already displayed for a Wall and make your settings there.
* You can transfer the settings of one placed Label to another using ALT-click, then CTRL-ALT-click.
