Wall Accessory Goodie or Badie ?
mthd
Hi to all timber wall framing users of AC. Has anyone been able to explode the wall framing object that creates the framing for a wall ? I need to display noggins or blocking mid way up the wall and to make many other edits that are not available in the parameters list. Also to edit the number of plates to top and bottom. To cut back to single header and it not auto default back to 90mm thickness.
I am not GDL minded so I don’t think I need to be in order to use AC down to a finer level of detail.
This accessory could be updated to allow for blocking, insulation, bracing and other necessary things for it to be useable on a structural level (Including tie down bolts and framing brackets etc).
Please also make it explodable so we can edit all framing members as we wish, for all our custom wall framing needs.
Edit: Please see this post about the same tool for more information about what could be done to improve it for us all.
https://community.graphisoft.com/t5/Modeling/Wall-framing-accessory-question/td-p/319759
Operating system used: Mac Apple Silicon Ventura
AC8.1 - AC29 ARM AUS + CI Tools
24C GPU 7.8TF 32GB RAM OS Sequoia.
Yes you have to create your schedule and tell it what criteria you want to find and what fields (values) you want to output.
But as you can see here, morphs do not have lengths, heights and widths.
The only thing that is common would be surface material or building material.
And maybe you could to a sum with total for the element IDs to get a count.
So, I probably should not have mentioned the classification, as you really can't get much useful information from it.
12 REPLIES 12
Steve Jepson
Useless Badie  🙂    It is more efficient to modeling the framing with *pre-modeled assemblies* that are easily adjusted per unique situations.  Its very easy to copy an assembly of header, trimmer, cripples, blocking.... form one project to another and adjust it for a new opening size.  And you can do that faster than you can configure the Wall Accessory Tool - which will never be exactly what  you want.
The same idea applies to just about everything you do with ArchiCAD.  Copy, Paste, Tweak... is almost always going to be more efficient than configuring Tools from scratch and never getting exactly what you want.
However, I should add that in my experience, exact quantities of framing lumber are very seldom more useful than approximations based on Estimating Formulas.
I suppose once you have set up your custom framing members with a template then start copying them around, then you would eventually save some time. (I have seen what they do at Contrabim)
Bear in mind that ArchiFrame has the ability to do all this and more in an automated way. Software is supposed to save us time and shouldn’t we let the program do the generic repetitive tasks for us ? After all isn’t it AI’s job to do some of that for us ?
The cost of ArchiFrame is supposed to be the same as a second license of AC. I think GS want us to use that instead of the old wall accessory goodie and that is probably why it hasn’t had the scripting updated. Good for those who can write GDL script.
I can't tell if this is a question (right forum) or a wish (should be in wishes forum - but infinitesimal chance of being granted).
The Wall Accessory Goodie is a "Goodie" download because it is unsupported.  In fact, it has received zero functional updates in about 24 years.  It cannot do spanning headers, different sized headers based on load, or any of the other things one would want for real framing.  It gives the illusion of framing only.
The entire wall framing object is a single object.  You could convert it to Morphs and edit it further that way (at which point it is no longer dynamically associated with the wall)... but it would be a painfully slow editing process after that.
As Steve said, it is more efficient and accurate to model the framing yourself... and re-use it in subsequent walls and projects.
Thanks Karl, I didn’t know about being able to convert it to morphs but that would certainly help in the process. I can easily add some elements around the morphs and delete the members that I no longer needed to use. The only problem then is creating a pricing list for those individual members.
Would be nice if in the future we could convert the morph geometry into a beam or a column etc ?
I rewrote the wall framing to do all of these things. As well as generate the data for quantity listing, I'm still working on the user interface but maybe it will be ready in the summer lol
Hi @SenecaDesignLLC, I saw that you had done some GDL work with the tool in the other post. That’s really cool that you can do that to generate realistic framing and quantity listing as well. I look forward to seeing what you have been able to do to improve it’s operation and use.
Wished for 12 years ago here:
https://community.graphisoft.com/t5/Wishes/Convert-Morph-to-each-elements/m-p/203836
and
https://community.graphisoft.com/t5/Wishes/Convert-morph-faces-to-walls-slabs-roofs-curtain-walls-sh...
I knew that wishes had been made regarding reversing the morph back to its original element. Must be a very difficult thing to do because the geometry of a morph is very different to regular elements. GS probably would have implemented it by now of it was feasibly possible ? The point is that morphed elements need to be kept track of so they can be reported to a BOQ (In the correct category or location) without it being lost somewhere in the project.
You can classify your morph as a beam, or a column or a framing stud or what ever you want.
This will allow you to include it in a framing schedule, but the problem then is, that a morph has different geometry to a beam or column.
i.e. a morph does not have a length like a beam does, or a width or a height.
So although you can tell your morph that is is indeed a beam or column, you may not be able to get the same data from it as a beam or a column.
You will only be able to get 'morph' related values - area in plan, volume, material, etc.
And you are correct.
There is no easy way to convert a morph back into a beam or column, which is why it has not been done.
Setup info provided by author
