Starting August 6, 2024, TLS 1.2 will be the minimum required protocol version for Graphisoft products and services that require an online connection. License Manager Tool update is required on Windows. Learn more…
Wall Intersection Behavior
I have a concrete wall abut a CMU wall, which has a lower priority. But I do not want the concrete to cross the CMU (see image to the left). Instead I want the concrete to stop at the face of the CMU like in image to the right where I left small gap so the two do not touch. Is there a way to eliminate the concrete wall crossing when the reference lines touch? Thanks.
Dontknow
Put the walls in different layers and adjust the priority.
helpcenter.graphisoft.com/guides/archicad-18-int-reference-guide/configuration/attributes/layers/use...
Architectural construction designer, draftsman, modeller
ArchiCAD 25.
Thank you very much.
