Wall W/ Custom Profile Doesn't Like Windows or Doors
I have just started making some custom wall profiles.
I am not able to put windows and doors into them without being informed that there are scripting errors.
It happens with the custom wall profiles provided by Graphisoft as well.
The window is there in 3D ok. 2D shows up a bit strange. If I attempt to mess with the window I get scripting error alerts all over.
Is there something simple I am missing before I wander any deeper into this?
21 REPLIES 21
David, thanks for the redirect. I will follow the thread and post back here if I have any luck.....
I have tried the link that David has posted and it does work. I had forgot all about that. I edited the master script and took part of the script out. I got the windows to work but since I am using log walls, the trim always wants to follow the curve of the log walls. If my window trim is at the inside edge of a log then my trim ends up hidden into the wall. I have not found a solution for this problem yet so that was the reason I gave up for now. I have too many things to get done first but once I play with it some more, maybe I will get it to work for me.
