Wall and Lines look thick in PDF
Hello, I saved a floor plan as a PDF and when I zoom in the PDF file, the lines look thicker than on my ArchiCAD file even though I chose the lightest line (the 1 Black 0.13 mm).
Anyone got an idea to fix this?
Thank you in advance.
Ilia
5 REPLIES 5
alemanda
check if the view placed in the layout has the same pen set you used in the model ...
eng. Alessandro Mandala - Italy
AC27 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores) - 32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 2560x1440
The pen set is scale 1:100 but my drawing on the layout is 1:200.. I don't know how to change it
alemanda
Select the drawing. Ctrl+T to open settings and there you find the scale
AC27 latest hotfix
Win 10 Pro 64bit
You can change the drawing scale here but you probably don't want to do that if it is scale you want.
You can also change the pen set being used so choose one that is appropriate for the scale of your drawing.
If you don't have a pen set for that scale you will have to create one.
Barry
Just to add, if you looking to do a quick print just for personal review, there is also a option when you have the print dialog open called hairline print, if you select that everything will print at 0.1 so you can read everything clearly.
But that being said its always good to print with true line wights to see what the outcome will be.
